Merge Survey Data into Assays
Use the Geochem Import > Merge and Verify menu option (CHMERGE GX) to merge the information from a Survey database into an Assay database.
Merge Survey Data into Assays dialog options
The "Sample" channel of the assay database is used to look-up all survey information from the Survey database.
Any mismatch between Sample numbers in either database will be reported in the merge report file.
All channels of the Survey database will be created in the Assay database, and all information will be copied to the Assay database. Normally, the Survey database is expected to contain the following channels, although it may contain any number of information channels that are relevant to the survey:
Sample |
The sample number. |
X |
Map X location of the sample. |
Y |
Map Y location of the sample. |
Sample_Type |
Blank - for normal samples |
