Profile Plot
Use the Geochem Map > Line Plots > Profile menu option (CHPROF GX) to draw profiles of channel values for all selected lines in a database.
Profile Plot dialog options
Profile channel |
Profile channel to select Script Parameter: PROFILE.CHANNEL |
Line colour |
line colour Script Parameter: PROFILE.COLOR |
Line thickness (mm) |
line thickness Script Parameter: PROFILE.THICKNESS |
Line style |
line style number Script Parameter: PROFILE.STYLE |
Line pitch (mm) |
line pitch Script Parameter: PROFILE.PITCH |
vertical scale in units/mm Script Parameter: PROFILE.SCALE |
Profile base |
profile base level, blank for line minimum Script Parameter: PROFILE.BASE |
Maximum down-line gap |
maximum down-line gap Script Parameter: PROFILE.GAP |
Join to line ends? |
1 - join line ends 0 - do not join line ends Script Parameter: PROFILE.JOIN |
This GX is for use with geochemical data acquired along survey lines.
