Save Statistics
Use the Geochem Analysis > Save Statistics option (CHPRSTAT GX) to print Assay channel statistics to a CSV file.
Output Assay Channel Statistics to a File dialog options
Mask channel |
Select a mask channel from the dropdown list. If the use of the mask channel is enabled, and set to this channel, only those data values whose corresponding mask channel value is not a dummy will be plotted or exported. Channels must have their CLASS attribute set to MASK to appear as selections in the drop-down list. If the mask channel does not exist, it will be created with its CLASS attribute set to MASK. The default mask channel is set from the CHPREFERENCES GX (Geochem Import/Preferences...). Script Parameter: CHPRSTAT.MASK |
Statistics to save |
"All ASSAY channels" – all channels that are members of the ASSAY class will be reported "Displayed ASSAY channels" – only displayed channels that are members of the ASSAY class will be reported. "Select ASSAY channels from list" -- select ASSAY class channels from a two-panel selection list. Script Parameter: CHPRSTAT.CHANNELS: One of "ASSAY", "DISPLAYED_ASSAY" or "LIST" |
The values are printed to a CSV (Comma-separated values) file, suitable for import into a spread-sheet program such as Microsoft ExcelÔ.
The following information is output for each channel:
Number of valid items
Number of items with values greater than 0
Number of non-valid (dummy) items
Minimum Value
Maximum Value
Range of Values (Max-Min)
Mean Value
Standard Deviation from the mean
Variance from the mean
Sum of values
Sum of the squares of values
Geometric Mean
Median Value
Modal Value
Standard Error
Skewness
Kurtosis
