Plot Triplot Graph
Use the CHPRTRI GX to print a TriPlot.
Plot Triplot Graph dialog options
Title |
Type the title for the TriPlot |
Triangle side length ( mm) |
Length of each side of the TriPlot triangle in (mm) |
Symbol Size (mm) |
The size of the plotted symbols in mm. |
Plot to |
Select one of "new map" or "current map". |
Locate Plot (plot to current map only)
Bottom left X (mm) |
X Location for bottom corner of the plot. |
Bottom left Y (mm) |
Y Location for bottom corner of the plot. |
Locate |
Interactively select the location of the bottom left corner by selecting a point on the current map |
Click on the Print button
in the Triplot Analysis tool.
Enter a title, the width and the symbol size for the plot.
New map names are created in the following format: Triplot_RightChannel_LeftChannel_TopChannel.map, or, if a template is specified using the GX parameters, the template name is used. If a map of that name already exists, it is overwritten.
