Symbol Plot Legend
Use the Symbol Plot Legend dialog (CHROSELEG GX, CHPIELEG GX, and CHBARLEG GX) to plot a legend for the Rose, Pie and Bar symbol plots.
Rose or Sector Plot Legend / Pie Symbol Plot Legend / Bar Symbol Plot Legend
If these GXs are run from the CHROSE, CHPIE or CHBAR GX, or immediately following them, the following parameters will already be set.
Specify Channels
Channel X |
Select a channel from the drop-down list. All values must be specified. Script Parameter: CHROSE.CHANX (Where X is a value from 1 to 8) |
Next> |
Proceed to define scaling. |
<Back |
Return to the main dialog |
Finish |
Plot the legend. If channels or colours remain to be defined, the appropriate dialog will appear before you can plot. |
Specify Scaling
Specify Fill Colours
(Channel Name) colour |
Select a colour from the drop-down list. All values must be specified. Script Parameter: CHROSE.COLX (Where X is a value from 1 to 8) |
<Back |
Finish |
These GXs are designed to be run from the CHROSE, CHPIE and CHBAR GXs, but may be run on their own.
