Create Subset Database
Use the Database Tools > Geostatistics Toolkit > Create Subset Database or the Geochem Analysis > Create Subset Database menu options, (CHSUBSET GX), to create a new SUBSET database from a Master database. The subset database will only include data that is not dummy in the Mask channel.
New subset database |
The new subset database you wish to create Script Parameter: CHSUBSET:DATABASE |
Mask channel |
The channel you wish to use as the mask channel. The default mask channel is set from the CHPREFERENCES GX (Geochem Import/Preferences...). Script Parameter: CHSUBSET:CHANNEL |
Used to generate a subset database, based on information contained within the mask channel (ChemMask)
