Clear View Mask
Use the Map Tools > Masking > Clear View Mask menu option (CLEARMASK GX) to clear the clip area in a view.
Clear View Mask dialog options
Map view |
The map view on which to apply the clip mask Script Parameter: CLEARMASK.VIEW |
Once a mask is applied to a view, the clipping remains in force for operations such as contouring, even if masking is turned off in all the groups in that view. In order for contouring to contour the grid to the full extent of the view, the clipping polygon must be removed using this GX.
