Quick Contouring
If you simply want to create a contour map for basic interpretation, you can use the quick contouring method. This method generates default contours based on your data values. Use the Map Tools > Contour > Quick menu option (CONTOUR GX) to draw contours on a map using a specified grid.
Quick Contour dialog options
Input grid |
Script Parameter: CONTOUR.GRID |
The contours are drawn using default settings.
