Copy Channel
Use the Database Tools > Channel Tools > Copy Channel menu option (COPY GX) to copy one channel to another.
Copy Channel dialog options
Copy from |
Original channel. Script Parameter: COPY.FROM |
Copy to |
Destination channel. Script Parameter: COPY.TO |
Decimation factor |
Decimation factor, default 1. Script Parameter: COPY.DECIMATE |
New start fiducial, defaults to FROM fiducial start. Script Parameter: COPY.FIDSTART |
New fiducial increment |
New fiducial increment, defaults to FROM fid increment. Script Parameter: COPY.FIDINCR |
If a new channel does not exist, it will be created with the same definition as the original channel. Where the mask channel value is a dummy "*", the copied value will be set to a dummy; otherwise the data is copied as is, subject to the usual rule on data conversion if the original and destination channels are different types.
