Subset Database
Use the Database > Export > Subset GDB or the Database Tools > Window Data > Subset Database menu options, (DBSUBSET GX), to create a subset database from the current database.
Subset Database dialog options
To create a subset database using a mask requires that a mask channel be defined such that the unwanted data is dummied out in the mask. For example, the data windowing functions can be used to window the X and Y channels based on a defined polygonal mask, and the "X" channel can then be used as the mask channel.
