Delete Line
Use the Project > Scripting > Delete Line menu option (DELLINE GX) to delete a line or a set of lines from a database.
Delete Line dialog options
Line number or range |
Lines to delete Script Parameter: DELLINE.LINE |
This GX will delete lines even if they contain channels that are marked as PROTECTED.
Lines may be selected by name or by range. For example:
L100.2 |
delete line 100 version 2 |
L80 |
delete line 80, all versions |
B80 |
delete base line 80, all versions |
T80 |
delete tie line 80, all versions |
R80 |
delete trend line 80, all versions |
S80 |
delete test line 80, all versions |
P80 |
delete special line 80, all versions |
D80 |
delete random line 80, all versions |
80 |
delete line 80, all versions, all types |
L100:300.3 |
delete lines 100 through and including line 300.3 |
