Differences
Use the Database Tools > Filters > Differences menu option (DIFF GX) to calculate differences between values in a channel.
The option is also available in the Moving Platform Gravity > 1D Filters menu.
Differences dialog options
Channel to difference |
Select input channel. Script Parameter: DIFF.IN |
Output difference channel |
Select output channel. Script Parameter: DIFF.OUT |
Number of differences (>=1) |
Number of differences. Script Parameter: DIFF.NUMBER |
Normalize differences? |
Select normalize difference "No", "Yes" (Default No). Output values are divided by 2 raised to the number of differences, e.g. for the 4th difference the values are divided by 16. Script Parameters: DIFF.NORM |
The common fourth difference can be calculated by specifying 4 differences. Fourth differences are useful for identifying noise in the data.
Differences with a dummy, result in a dummy.
Even numbers of differences produce properly located results. Odd numbers of differences will locate the result 1/2 element below the actual location.
The difference filter is calculated by the subtraction of the successive data values of the channel:
Higher differences are formed by successive operations, for example:
D3(V(i)) = V(i+2) - 3V(i+1) + 3V(i) -V(i-1)
D4(V(i)) = V(i+2) - 4V(i+1) + 6V(i) - 4V(i-1) + V(i-2)
