Re-Fid a Channel to a Distance Base
Use the 1D FFT > Advanced Settings > Re-Fid to Distance menu option (DISTFID GX) to create a distance-based channel from a fiducial-based channel.
Re-Fid to Distance dialog options
This GX uses a channel named "_Distance" as the distance reference channel. If this channel does not exist, the "X" and "Y" channels are used to create a "_Distance" channel, which will contain the cumulative down-line distance starting at 0.
If you would like to use some other reference channel, perhaps the "X" or "Y" channels directly, copy the desired reference channel to a channel named "_Distance" before running the DISTFID GX. Note that the new channel should only be viewed or processed with other distance-based channels.
