Plot Datamine Polygons to Drillhole Sections
Use the DMPLOTPOLY GX to plot Datamine polygons to Drillhole sections for editing.
Plot Datamine Polygons to Drillhole Sections dialog options
Load the Menu
There is no bar menu for the Datamine polygon editing GXs; however, by loading the "DMPoly.omn" file, the various GXs become available from the right-mouse button menu when a map is selected.
General Usage
Currently, one section is drawn for each selected polygon. Vertices may be moved, added, or deleted (labeled vertices cannot be deleted).
The map tools for moving, adding or deleting polygon vertices cannot, at present, be used for modifying the polygon, because of the need to track which of the vertices are labeled, and to prevent the deletion of the those vertices.
All modifications are performed in the plane of the polygon.
It is recommended that you create a copy of the polygon file before editing it. Changes made to the polygon are immediately saved to the polygon file itself, and cannot currently be undone.
Once you select OK in the dialog, a list of the available polygons is displayed. Select one or more. Each selected polygon is plotted to its own Drillhole Section map.
Define Drillhole Section Parameters for Polygon Plots
The Datamine polygon GXs use the Drillhole parameter file "DMEdit.ins" to control the section creation. To create this file, define the section parameters as normal in the Section Parameters tabbed dialog (DH_Sect | Section), then go to the Load/Save tab and save the current parameters, selecting "DMEdit.ins" as the output file.
