Array To Database Channels
Use the Database Tools > Array Channels > Array To Database Channels menu option (geogxnet.dll(Geosoft.GX.Database.ArrayToChannels;Run)*) to select an Array channel to be displayed as standard database channels.
Array To Database Channels dialog options
Array channel |
Using the Array channel drop-down list, select an Array channel from your current database. |
Array channel elements |
The array channel elements for your selected array channel are displayed in the Array channel elements list. |
Database channels |
The individual channels from your selected array channel are displayed in the Database channels list. |
[Add] |
Select (highlight) the array channel elements to be displayed as standard database channels. Click the Add -> button to move the selected array channel elements to the Database channels list. |
[Remove] |
Select (highlight) the database channels to be removed. Click the <- Remove button to move the selected database channels to the Array channel elements list. |
