Calculate and Display Analytic Signal Grid
Use the Euler 3D > Calculate and Display Analytic Signal Grid dialog option (E3ASIG GX) to compute the analytic signal grid from existing derivative grids.
Calculate Analytic Signal dialog options
Input X-derivative grid |
Input X-derivative grid Script Parameter: EULER3D.DX |
Input Y-derivative grid |
Input Y-derivative grid Script Parameter: EULER3D.DY |
Input Z-derivative grid |
Input Z-derivative grid Script Parameter: EULER3D.DZ |
Output analytic signal grid |
Output analytic signal grid Script Parameter: E3ASIG.ASIG |
Display AS grid in new map ? |
Display analytic signal grid (1) or to the current map (0) Script Parameter: E3ASIG.NEW |
Calculation of analytic signal:
The analytic signal is the square root of the sum of the squares of the derivatives in the x, y, and z directions:
asig = sqrt ( dx*dx + dy*dy + dz*dz )
The analytic signal is useful in locating the edges of magnetic source bodies, particularly where remanence and/or low magnetic latitude complicates interpretation.
Display of analytic signal grid:
If the grids are to be displayed in a new map, an additional dialog box will appear requesting the map name. Map layout, style and title settings may be defined using the MAP OPTIONS button. Pressing the button initializes a series of dialog boxes in which the map settings may be defined. Subsequent maps will default to the settings used.
