Get Grid Peak Locations
Use the Get Grid Peak Locations dialog options (E3PEAKS GX) to automatically select solution picks from a grid.
The peak locations are selected using a grid peak-picking algorithm, are stored in the current database and are displayed as symbols on the current map.
Locate Grid Peaks dialog options
Output Channels
The X and Y coordinates of the selected peaks are placed in the X and Y channels respectively in the specified line. The grid values at the peak locations used to pick the locations are placed in the specified grid value channel (if grid smoothing is selected these will be the smoothed values). A Target_ID channel is also created, and peaks are numbered sequentially, beginning at 1.
