Select All
Use the Euler 3D > Select All menu option (E3WINDRS GX) to select all solutions from a selected Euler deconvolution solution set, using the mask channel.
Select All Euler Decon Results dialog options
Solution list |
The Name of the "group" line with solutions. This value is the same as the most recently specified solution list from any of the other GXs that require a Solution List. Script Parameter: EULER3D.SOLUTIONS |
Mask channel |
The mask channel is updated by the windowing operation. The mask channel is used for selecting a subset of solutions from the solution list. This channel is initially set 1 to indicate that all solutions are selected. If the value is set to 0 or dummy (*), then this solution will be ignored in operations making use of the mask channel. Script Parameter: EULER3D.MASK |
Applications Notes
This GX is useful in the case of restarting to window the data after using E3WINDOW to select solutions.
