Select Map Groups to Export
Use this dialog to select which visible map groups to export to a 3D DXF file.
Select Map Groups to Export dialog options
Not SelectedThe items displayed in this panel are not selected for processing. |
SelectedThe items displayed in this panel are selected for processing. |
Press this button to select all of the items in the "Not Selected" list. |
Press this button to select one (highlighted) item in the "Not Selected" list. |
Press this button to deselect one (highlighted) item in the "Selected" list. |
Press this button to deselect all of the items in the "Selected" list. |
Press this button to reverse the "Selected" and "Not Selected" lists. |
Only visible map groups appear in the selection tool. Not all map groups can be exported to a 3D DXF file, so there may be selected map groups, or items in the selected map groups that will not be exported. Exportable plot entities include lines, polylines, polygons and surfaces. Symbols, and 3D objects such as spheres, cylinders and boxes are exported as simple points. Non-exportable items include Grids ("AGG_" groups) and Voxels.
