Export Data to Geosoft GBN
Use the Database > Export > Geosoft GBN menu option (EXPGBN GX) to export data to a Geosoft binary (GBN) file. Either displayed data channels or all data channels may be exported, and the displayed line, selected lines or all lines may be exported. If the output file(s) already exist, they will be overwritten.
To export data to a Geosoft binary file:
On the Database menu, select Export then Geosoft GBN.
The Export to Geosoft GBN dialog is displayed. -
In the Output GBN file name text box, specify the new file (*.gbn).
- Select the Channels to save from one of the options below:
- Select the Lines to save from one of the options below:
- Selected lines
- Displayed line
- All lines
Click the OK button, and the data is exported to a Geosoft GBN file format.
Export to Geosoft GBN dialog options
Output GBN file name |
The new file name, .gbn assumed. Script Parameter: EXPGBN.FILE |
Channels to save |
Select "Displayed channels" or "All database channels". Script Parameter: EXPGBN.CHAN |
Lines to save |
Select "Displayed line", "Selected lines" or "All lines". Script Parameter: EXPGBN.LINE |
