Butterworth Filter
Use the Butterworth option to apply a Fast-Fourier Transform Butterworth filter to a channel.
  • Geophysics: 1D FFT > 1D Filtering
  • Gravity and Terrain Correction: Moving Platform Gravity  > Apply Single FFT Filter
Butterworth filter options
Central Wavelength cutoff (in ground units)
Central Wavelength cutoff value, in ground units (Default 1)
Script Parameter: FFTBUTTW.WAVEL
Degree of Filter
Degree of the Filter function (default = 8)
Script Parameter: FFTBUTTW.DEGREE
Low or High Pass Filter
Low or High Pass filter (default = Low)
Script Parameter: FFTBUTTW.PASS
The Butterworth filter is excellent for applying straight forward high-pass and low-pass filters to data because you can easily control the degree of filter roll-off while leaving the central wavenumber fixed. If ringing is observed, the degree can be reduced until acceptable. A common, but more complicated alternative is the Cosine Filter).
Butterworth Filter
Parameters:
k0
Central wavenumber of the filter.
n Degree of the Butterworth filter function. By default, we assume a degree of 8.
0/1
Residual/Regional flag to specify if a residual high pass or a regional low pass is required. By default, the system applies a regional filter.
