Apparent Density Calculation Filter
Use the Apparent Density Calculation option to apply a Fast-Fourier Transform Apparent Density filter to a channel.
  • Geophysics: 1D FFT > 1D Filtering
  • Gravity and Terrain Correction: Moving Platform Gravity  > Apply Single FFT Filter
Apparent Density Calculation filter option
Depth to the top of model
Depth to the top of the model. Default = 1
Script Parameter: FFTDENS.DEPTH
Thickness of earth model
Thickness of earth model. Default = 1
Script Parameter: FFTDENS.THICK
Low-pass cutoff
(in ground units)
Low-pass Butterworth filter cutoff wavelength. Default = 1
Script Parameter: FFTDENS.LP
Background Density
(g/cm3)
Background density (g/cm3). Default = 0
Script Parameter: FFTDENS.DENS
In order to have correct density units, the input data fiducial base must be in metres. The low-pass filter can be used to remove noise in the data that would be amplified by the downward continuation. A low-pass cutoff of 1 to 1.5 times the depth is normally appropriate.
Apparent Density Filter
Parameters:
t Thickness, in ground_units, of the earth model.
d Background density in g/cm3
G Gravitational constant.
