Resistance Capacitance Filter
Use the Resistance Capacitance option to apply a Fast-Fourier Transform Resistance Capacitance filter to a database channel.
- Geophysics: 1D FFT > 1D Filtering
- Gravity and Terrain Correction: Moving Platform Gravity > Apply Single FFT Filter
Resistance Capacitance filter options
Central Wavelength cutoff |
Specify the Central Wavelength cutoff value, in ground units. (Default is 1) Script Parameter: FFTRC.WAVEL |
Low or High Pass Filter |
Select Low or High Pass filter. (Default is Low) Script Parameter: FFTRC.PASS |
The Resistance Capacitance filter is excellent for smoothing the gravity data.
Parameter:
| kc |
Central wavenumber of the filter. |
