Upward Continuation (CNUP)
Use the Upward Continuation option to apply an upward continuation filter.
Upward Continuation dialog options
Distance to upward continue |
The distance h in ground units, to continue up relative to the plane of observation. |
Upward continuation is considered a clean filter because it produces almost no side effects that may require the application of other filters or processes to correct. Because of this, it is often used to remove or minimize the effects of shallow sources and noise in grids. Also, upward continued data may be interpreted numerically and with modelling programs. This is not the case for many other filter processes.
Upward continuation
Where:
h |
Distance in ground units, relative to the plane of observation tocontinue up. |
Wavenumber domain variable definition
k |
u |
v |
r |
θ |
