Gravity Earth (GFILT)
Use the Gravity Earth Filter option to apply a gravity earth filter.
Gravity Earth Filter dialog options
Depth to top of layer |
Specify the depth to top of layer in ground units. |
Depth to bottom of layer |
Specify the depth to bottom of layer in ground units. |
Use the Gravity Earth Filter to calculate the gravitational field of the horizontal earth layer that resides between two user defined depths. This filter is implemented to be used by GM-SYS.
When r = 0,
Where:
G |
Gravitational constant. |
z1 |
Depth to the top of the density layer, in ground units, of the earth. Must be positive for layers above calculation level. |
z2 |
Depth to the bottom of the density layer, in ground units, of the earth. Must be positive for layers above calculation level. |
Wavenumber domain variable definition
k |
u |
v |
r |
θ |
Reference
- R. J. Blakely, Potential Theory in Gravity and Magnetic Applications, (Cambridge University Press, 1996).
