Vertical Integration (INTGZ)
Use the Vertical Integration option to apply the vertical integration filter.
Vertical Integration dialog options
There are no dialog options for this filter. Click OK on the dialog to apply the filter.
This filter calculates the vertical integral of the input transform. This is the inverse of the vertical derivative. The zero wavenumber is set to 0.
Vertical integration
L(r) = r-1
Wavenumber domain variable definition
k |
u |
v |
r |
θ |
