Sensor Offset Correction
Use the Moving Platform Gravity > Navigation Corrections > Offset Correction menu option, (geogxnet.dll(Geosoft.GX.Gravity.OffsetCorrection;Run)*), to calculate the true X, Y, Z coordinates of a sensor, located at a fix offset from the GPS receiver. This dialog operates on the current database and expects that the X,Y,Z channels are assigned.
Offset Correction dialog options
Sensor offset in direction of travel
Specify the distance of the sensor ahead (positive) or behind (negative) to the GPS receiver, relative to the line direction.
Script Parameter: GRAVITY_OFFSET_CORRECTION.OFFSET_ALONG
Sensor offset across direction of travel
Specify the offset distance of the sensor perpendicular to line direction (positive to right, negative to left, relative to line direction).
Script Parameter: GRAVITY_OFFSET_CORRECTION.OFFSET_ACROSS
Sensor vertical offset
Specify the vertical offset distance of the sensor above (positive) or below (negative) to the GPS receiver, relative to the line direction.
Script Parameter: GRAVITY_OFFSET_CORRECTION.OFFSET_VERTICAL
The Offset Correction dialog calculates the new X,Y,Z coordinates and sets them as the assigned coordinates. The new channel names are set as the existing channels suffixed by '_offset'.
