Merge with Master Database
Use the Gravity > Merge with Master Database menu option (GRAPPEND GX) to append one or more gravity survey databases to a master gravity database.
Merge with Master Database dialog options
Gravity survey database(s) |
The name of the gravity survey database(s) to append. Script: GRAPPEND.SURVEY |
Master gravity database |
The name of the master database. Script: GRAPPEND.MASTER |
Select Master Channels dialog options
Station channel |
Select the station channel. Script Parameter: GRAPPEND.STATION |
Longitude channel |
Select the longitude channel. Script Parameter: GRAPPEND.LONGITUDE |
Latitude channel |
Select the latitude channel. Script Parameter: GRAPPEND.LATITUDE |
The second dialog, Select Master Channels, is displayed when any of the following channels, "Station", "Longitude" or "Latitude", does exist under a different name in the gravity survey database. In this case, the user must manually select the channel(s) from the survey database. The append operation will then proceed as below:
- The alternately named channels are copied to their hard-wired target channel names in the survey database.
- If the hard-wired name already exists, i.e., you have both Latitude and LatGPS channels, and want to use the LatGPS as the "Latitude" channel in the master database:
- The existing hard-wired channel name is changed by pre-pending an underscore , i.e "_Latitude"
- The LatGPS values are copied to the Latitude channel.
- The append operation is performed. This appends the data as intended, but still copies the data from the "original" alternate channels by their original names.
Only stations of type 1, or dummy (*) are appended. Base stations (Type 0) are not appended. If you would like to flag certain readings not to be appended to the master database, change the type to a value other than 1 or dummy (*).
