Create Calibration from File
Use the Gravity > Calibration > Create Calibration from File menu option (GRCALFILE GX) to create a calibration table file from an existing calibration data file that is in some other format.
Format a Calibration Table from a File dialog options
Calibration tables are often formatted into two columns of instrument reading and the calibrated milligal equivalent. If you have an existing calibration data in this format, this GX will create a template for a Geosoft compatible file and append the contents of your file. You can then edit your information to the specification of the template.
A calibration file is a standard Geosoft ASCII comma-delimited table file, which contains a "Instrument", "Milligal" and "Scale" column as in the following example:
/ Survey date: 1988/11/14
/ Instrument: G 123
/ Survey database: .\Nov14.gdb
/ Base station database: .\bases2.gdb
Instrument, Milligal
5090.5705, 981200.0819
5098.0000, 981210.0840
5110.0000, 981220.0836
5122.0000, 981230.0833
5133.0000, 981240.0830
5144.0000, 981250.0827
To use a calibration file, the calibration file name must be specified in the survey Processing Parameters (Processing Parameters).
