Grid Outline
Use the Grid and Image > Utilities > Grid Outline menu option or the Grid Knitting > Grid Outline menu option, (GRID2PLY GX), to find edge points in a grid image, and either save the edges in a polygon file or draw the edges on the current map.
Grid Outline dialog options
Save Edges in a Polygon File
Polygon file name (.ply) |
A polygon (.ply) file name Script Parameter: GRID2PLY.PLY |
Save mode |
"New file" to save in a new file. Script Parameter: GRID2PLY.MODE |
Edge resolution for thinning. Default is 1 cell – no thinning. EdgeRes> 1 will thin the edge points to resolve the edge to a courser sample. Script Parameter: GRID2PLY.EDGERES (Default 1.0) |
Draw Grid Edge on the Map
Only the outside edge of the first encountered non-dummy area of the grid isoutlined. Holes and islands are not recognized.
If saving the grid outline to a polygon file, the polygon file can be used for the following purposes:
• As a mask outline by the masking functions.
• To be drawn on maps using the POLYDRAW GX.
• For use by other programs.
Parameter Edge Resolution is for edge thinning action, i.e. to remove "colinear" points outside of this specified resolution to resolve the edge to a courser sample.
Thinning is disabled for map output when set to less than zero (0.0), and is applied for output to a file only if set to larger than the "X" cell size.
