Add/Subtract Two Grids
Use the Add/Subtract Two Grids option (GRIDADD GX) to add two grids together or subtract one grid from another to produce a new grid. Multiplying factors may be applied to each grid before the addition. Subtraction can be achieved by using multipliers of +1 and -1.
Add/Subtract Two Grids dialog options
File Name of the First Grid. (.grd file) Script Parameter: GRIDADD.GRD1 |
Input grid file 2 |
File Name of the Second Grid. (.grd file) Script Parameter: GRIDADD.GRD2 |
Multiply grid 1 by: |
Multiplier to Apply to First Grid (before addition occurs). Default = 1. Script Parameter: GRIDADD.MUL1 |
Multiply grid 2 by: |
Multiplier to Apply to Second Grid (before addition occurs). Default = 1. Script Parameter: GRIDADD.MUL2 |
New resultant grid |
File Name of New Grid. (.grd file) Script Parameter: GRIDADD.NEW |
Addition of the grids occurs grid point by grid point. Subtract grid #2 from grid #1 by applying a multiplier of -1 to grid #2.
Following are examples where adding or subtracting grids can be useful:
A regional (smoothed) grid may be subtracted from the original grid to produce a residual.
In magnetic surveys, the IGRF (International Geomagnetic Reference Field) may be calculated at a small number of points within an area and gridded separately. This grid may then be subtracted from the total magnetic field to effectively remove the IGRF.
If grid 2 does not match grid 1 in coordinate system, grid size or cell size, it will be sampled to match grid 1 and the result grid will be spatially equivalent to grid 1.
