4-Grid Composite
Use the Grid and Image > Display on Map > 4-Grid Composite menu option (GRIDIMG4 GX) to place an aggregate of 4 grid images on a map.
4-Grid Composite dialog options
Colouring method |
Select the colour method as one of the following options: As last displayed, Default, Histogram equalization, Normal distribution, Linear, Log-linear.
If the selected colour scheme is an .itr file or a .zon file, the colours are already attributed to data ranges, and this entry remains disabled. Script Parameter: GRIDIMG4.ZONE |
Grid name 1 |
first grid name Script Parameter: GRIDIMG4.GRID1 |
Colour table 1 |
Select the colour scheme for rendering the image of the first grid. If you mouse over the colour scheme entry, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour entry and then navigate through the scheme categories. Script Parameter: GRIDIMG4.COLOR1 |
Grid name 2 |
Second grid name Script Parameter: GRIDIMG4.GRID2 |
Colour table 2 |
Select the colour scheme for rendering the image of the second grid. If you mouse over the colour scheme entry, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour entry and then navigate through the scheme categories. Script Parameter: GRIDIMG4.COLOR2 |
Grid name 3 |
Third grid name Script Parameter: GRIDIMG4.GRID3 |
Colour table 3 |
Select the colour scheme for rendering the image of the third grid. If you mouse over the colour scheme entry, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour entry and then navigate through the scheme categories. Script Parameter: GRIDIMG4.COLOR3 |
Grid name 4 |
Fourth grid name Script Parameter: GRIDIMG4.GRID4 |
Colour table 4 |
Select the colour scheme for rendering the image of the fourth grid. If you mouse over the colour scheme entry, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour entry and then navigate through the scheme categories. Script Parameter: GRIDIMG4.COLOR4 |
Render method |
Select the render method. ADD - All the colours are added together. BLEND – All the colours are added then divided by the number of valid (non-dummy) colours. BLEND EQUAL – All the colours are added then divided by the number of colours. Script Parameter: GRIDIMG4.METHOD |
Click the New Map button to display a grid on a new map. Click the Current Map button to display the grid on the current map. (For script file, set Script Parameter: GRIDIMG4.NEW to 1 to create a new map; 0 to use current map)
