Create Grid from Section Line
Use the Create a Grid from a Section Line dialog (GRIDSECTION GX) to create a grid from section data stored in a single line.
Create a Grid from a Section Line dialog options
Output grid |
Name of the file to write the TIN information to. This is a binary file and cannot be read using a text editor program. The saved file can then be used as input to other GXs, such as TINMESH. Script Parameter: TINDB.FILE |
X (along ground) channel
The position along the section. Usually the X or Y channel. Script Parameter: GRIDSECTION.X (Default X) |
Z (elevation) channel
The elevation of the point in the section. Usually the Z channel. Script Parameter: GRIDSECTION.X (Default Z) |
Grid value channel
The channel containing values to grid. Script Parameter: GRIDSECTION.GRIDVAL |
Grid cell size |
The output grid cell size. The output grid is created to cover the full range of the input data. Script Parameter: GRIDSECTION.CELLSIZE |
Section information can be stored to a line. For instance, the line can contain X, Y and Z values, with either the X or Y values held constant and the Z values indicating the elevation of the position in the section. The method creates a Triangular Irregular Network (TIN) of the points, then uses the TIN Nearest Neighbour Algorithm to calculate the values at the grid nodes.
The current displayed line is used.
