Grid Point Value
Use the Grid and Image > Utilities > Point Values menu option (GRIDVALUE GX) to calculate and report the grid value at a selected location from up to four grid files.
Point Values dialog options
Grid 1 |
The names of up to four grids to report. Script Parameter: GRIDVALUE.GRD1 Script Parameter: GRIDVALUE.GRD2 Script Parameter: GRIDVALUE.GRD3 Script Parameter: GRIDVALUE.GRD4 |
[Point] |
After pressing this button you will be able to select a point on the current map. The values of each of the specified grids will be reported in a separate dialog. |
Grid Values at a Point dialog options
Map X |
This is the X, Y location that has been selected. You can change these values directly in the dialog to determine the grid values at a specific location. |
Grid name |
The name of each grid specified appears with the grid value at the selected point. |
[Point] |
After pressing this button you will be able to select a new point on the current map. The values of each of the specified grids will be reported. You can also just press return, then click on a new location. |
[Calc] |
If you have changed the X, Y values directly, this button will calculate the grid values at the new location. |
After pressing the Point button, you will be able to select a point on the current map. The values of each of the specified grids will be reported in a separate dialog.
