Import/Append Location Data
Use the Gravity > Locations > Import/Append Location Data menu option (GRLDXYE GX) to import location data into the location database of the gravity project.
Import/Append Location Data dialog options
Location database |
The name of the location database. If the database does not exist, it will be created with channels of "Station", "Longitude", "Latitude", "X", "Y" and "Elevation". You will also have the option to load existing location data from another database or a text file. Script Parameter: GRAVRED.LOCATION_DATABASE set by GRPARM GX |
Location data source |
Choose the data source as a Geosoft Database (gdb) file or a Text data file (see the Application Notes below for ASCII CSV file format requirements). Script Parameter: GRLDXYE.TYPE |
Load Location Data from Text Data File/ Database dialog options
Location file to load /Location survey database |
Select the database or file to import based on the Location data source option. Script Parameter: GRLDXYE.FILE |
Overwrite existing locations? |
Select the import option. If "Yes" is selected and the imported data contains stations already present in the location database, the existing locations will be deleted and replaced by the imported data stations. Note that the replacement row(s) will be appended at the end. If "No" is selected, any existing locations will be skipped. Script Parameter: GRLDXYE.OVERWRITE [0 - No (default), 1-Yes] |
The next dialog is contextual and will only appear if any of the default channel names Station, Longitude, Latitude, are not found in the data source file.
Select Master Channels
Station channel |
Select the name of the station channel from the drop-down list of source file fields. Script Parameter: GRAVRED.STATION |
Longitude channel |
Select the name of the longitude channel from the drop-down list of source file fields. Script Parameter: GRAVRED.LONGITUDE |
Latitude channel |
Select the name of the latitude channel from the drop-down list of source file fields. Script Parameter: GRAVRED.LATITUDE |
If the above dialog is invoked, the log file, MergeLocations.log, is created (or updated) in your working directory. This log file lists the names of the imported fields to each of the channels, Station, Longitude, and Latitude.
Location data is loaded/ imported into the location database either from an existing Geosoft Database or from a comma delimited text file that contains location information. Regardless of the channel name discrepancy between the source file and the location database, the data is imported into the standard channels below.
"Station" |
A unique station number that is used to look-up locations during the drift correction or when you merge location data using the "Merge with survey data…" (GRMGXYE GX). |
"Line" |
The "Line" channel will only be present if there is "Line" data in the imported location file. If "Line" is present, station locations are based on a unique Line and Station. This may be the case if a gravity survey is conducted on a local line/station oriented survey grid. |
"Longitude" |
The geographic location of the station. If only a local grid "X" or "Y" is provided, these values will appear as dummies. The "X,Y -> Longitude, Latitude…" (GRLL2XY GX) can be used to calculate longitudes and latitudes from local X,Y coordinates. |
"X" |
The local map X,Y coordinate of the station. The X,Y coordinates may also be in a known map projection. If only a longitude, latitude locations are provided, these values will be dummied. The "Longitude, Latitude -> X,Y…" (GRXY2LL GX) can be used to calculate X,Y coordinates from Longitude, Latitude coordinates. |
"Elevation" |
The station elevations. |
See Open/Create Location Database (GRXYEDB GX) for more information on establishing locations.
ASCII CSV File Format
Location data stored in an ASCII CSV file (Comma Separated Value) should look like one of the following examples (the order of the columns is not important):
1,-89.2123166667,48.1929916667,100,0,340
2,-89.2136722222,48.1942,100,25,342
3,-89.2106166667,48.1948666667,100,50,329
Line,Station,X,Y,Elevation
100,0,100.25,0,340
100,25,100.25,26.5,342
100,50,105,52.1,329
Station,Longitude,Latitude,Elevation
1,-89.2123166667,48.1929916667,340
2,-89.2136722222,48.1942,342
3,-89.2106166667,48.1948666667,329
Geographic coordinates can also be specified using the format "deg.mm.ss.ss".
Distance Units
Distance units are assumed to be degrees for geographic longitude, latitude and metres for "X", "Y" and "Elevation". The distance units can be changed when data is converted between X,Y and geographic coordinates, or the units can be set by editing the channel attributes and specifying the unit abbreviation (click once on a channel name, then right mouse and select "Edit").
