X,Y to Longitude,Latitude
Use the Gravity > Locations > X,Y -> Longitude,Latitude menu option (GRXY2LL GX) to convert projected map or local coordinate system X/Y coordinates to longitude/latitude.
X,Y -> Longitude,Latitude dialog options
Conversion method |
Select the Projected coordinate system method to use a map projection. Select the Local coordinate system method to use origin and azimuth. Script Parameter: GRXY2LL.METHOD |
This procedure is useful if you have data points with known longitude and latitude coordinates, and you would like to work on a map/local X, Y coordinates.
For the "Projected" method, the X, Y coordinates are calculated based on a projected map coordinate system by running NEWXY GX.
For the "Local" method, the X, Y coordinates are calculated by projecting longitude/latitude coordinates to a Transverse Mercator projection with a central meridian through the specified local (X, Y) and then rotating to the required Y azimuth by running LL2XY GX. A local coordinate system is an arbitrary Cartesian coordinate system that has been located and oriented for the purposes of a particular study.
