Run GX
Use the Project > Run GX menu option (or click the Run GX icon on the Project Explorer toolbar) to open the Run GX dialog and run a GX.
You can run only the GXs for which you are licensed.
Run GX dialog options
GX file
The name of the GX file. Browse button will display GX files in the GEOSOFT directory.
History
Switches the dialog to "History" mode to enable you to select GXs from a history list of GXs that have been run from this tool.
Browse
Click the Browse button to display the GX files in the "gx" directory. Select the GX file you wish to run. Click Open to select the file and then click OK to run the GX.
History
Click the History button to switch the dialog to "History" mode, which enables you to select the GX from a history list of GXs that have been run from this tool.
