Import GOCAD Surface(s)
Use the Imports > GOCAD Surface(s) option (geogxnet.dll(Geosoft.GX.Map.ImportGOCADSurface;Run)*) from the 3D Viewer > Add to 3D menu to import a GOCAD surface file into a Geosoft surface (geosurface) file.
A new geosurface file can be created, or the GOCAD surface can be appended to an existing geosurface file. The geosurface file is added to the current project (Project Explorer > Geosurfaces) and to the current 3D View.
Import GOCAD Surface(s) dialog options
GOCAD surface(s) |
Select one or more GOCAD files to import and display. Script Parameter: IMPGOCADSURFACE.FILE (Separate files with the "|" character). |
Geosurface file |
Specify the name of the geosurface file (*.geosoft_surface). Automatically pre-populated with the same file name as the input file. Script Parameter: IMPGOCADSURFACE.SURFACEFILE |
Invert Z values |
The default is Z+ up. If your GOCAD t-surface is set to have Z- down, then select this option to invert the surface in the 3D View. Script Parameter: IMPGOCADSURFACE.INVERT_Z (0: No (default), 1: Yes) |
Import file |
The output will be saved to a new or existing geosurface file. The new or existing geosurface will be displayed in the 3D View. Script Parameter: IMPGOCADSURFACE.GEOSURFACE_EXISTING (0: Create new (default), 1: Append) |
GOCAD Coordinate System
Coordinate system |
The Coordinate System dialog allows you to specify the correct coordinate system information for the incoming GOCAD file. Use the drop-downs to define a coordinate system for the GOCAD surface file. The GOCAD coordinates will be re-projected from this coordinate system to the 3D View coordinate system if necessary. If multiple GOCAD files are selected, the specified coordinate system will be applied to all files. Script Parameters: IMPGOCADSURFACE.IPJ_NAME IMPGOCADSURFACE.IPJ_DATUM IMPGOCADSURFACE.IPJ_METHOD IMPGOCADSURFACE.IPJ_UNITS IIMPGOCADSURFACE.IPJ_LOCALDATUM |
The colours specified in the GOCAD surface file will be used in the display. These can be edited in the Attributes tab.
