Orient a Grid
Use the 3D View > Orient a Grid menu option (IMGORIENT3D GX) to set up or modify the orientation of a grid in 3D space.
Orient a Grid dialog options
If you find that the reference point location values of a grid which already possesses an orientation are not what you remember setting them to, it may be because the last Reference Point selection for this GX was not the same reference point used when the grid orientation was first defined. See the notes above about the Reference point and Reference point location in the Default button, which explains why this might be so, and how to recover the original values.
