Import AMIRA File
Use the Database > Import > AMIRA > Import AMIRA File menu option (IMPAMIRA GX) to import an AMIRA file into a Geosoft Database. The data will be imported and displayed as an Array in the database spreadsheet window.
Import AMIRA File dialog options
AMIRA file name |
Input an AMIRA data file name ( *.tem ). Script Parameter: IMPAMIRA.FILE |
The standard AMIRA file format used for the storage of TEM data consists of four parts: Title, Constant Definitions, Column Definitions, and Data Records.
This GX saves the constants defined in the AMIRA into an embedded file in the database, which can be viewed by a separate GX program AMRCONST.GX. The column definitions will be used to create channel names. If COMPONENT is defined in the Constants part of the AMIRA file (normally X, Y and Z), it will be used as part of the data channel name.
