Import Datamine DM File(s)
Use the Map > Import > Datamine DM File(s) menu option (IMPDATAMINE GX) to import a Datamine (*.dm) file into an Oasis montaj map.
Use the Add to 3D > Imports > Datamine DM File(s) menu option (IMPDATAMINE GX) to add a Datamine (*.dm) file to a 3D View.
Datamine File Import dialog options (3D View)
Datamine file(s) |
Select one or more Datamine (*.dm) files to import. Script Parameter: IMPDATAMINE.FILES (Separate files with the "|" character. |
Import Datamine DM File(s) dialog options (Map)
Datamine file(s) |
Current Map |
Click this button to import the file(s) to the current map. Script Parameter: IMPDATAMINE.MAPOUT (Option: 0 : Current Map) |
New Map |
Click this button to import the file(s) on a new map. Script Parameter: IMPDATAMINE.MAPOUT (Option: 1 : New Map) |
Import to a New Map dialog options
Create a New Map dialog options
Map name |
Specify the name of the new map. Automatically pre-populated with the same name as the input Datamine DM file name. Script Parameter: IMPDATAMINE.MAP |
If the Datamine DM file(s) are imported to a current map, the imported data will be projected onto the plane of the current data view. If the view is a normal "plan" view, then the Z-dimension information will be lost. If the view is a "section" view (such as those created for drillhole sections in Target), the data is projected horizontally onto that plane. If imported to a 3D View, the objects are plotted as in the original files.
The following Datamine file types are currently supported:
Often, Datamine files can be opened and interpreted as two or more different types of files. For instance, as a Wireframe point file and as a string file. In these cases, a dialog is displayed for the user to select which of the types to select. Do not select the wireframe point option unless you have the accompanying wireframe triangle file.
