Import Single Table
Use the Database > Import > Database Table > Single Table menu option (IMPDB GX) to import external file databases into a Geosoft database (GDB). The GX assumes that the database is a Microsoft Access database (with a .mdb file extension). If it is not, and the system can not identify its type, the system prompts you for it. The supported databases depend on the ODBC drivers that have been installed on the system.
Import Single Table dialog options
The following lists the typical ODBC drivers that come installed with a Microsoft Windows system:
Microsoft Access Driver (*.mdb)
Microsoft dBase Driver (*.dbf)
Microsoft Visual FoxPro Driver
The system creates an import template "impdb.i4" at import time. This is to enable advanced users to tailor the import channel name or data type (for automated import) using GX Developer functions.
- SQL (Structured Query Language) is a computer language designed to store, manipulate, and retrieve data from a relational database. SQL commands are used to select data from the tables located in a relational database.
- For more information on SQL visit http://en.wikipedia.org/wiki/SQL
- For a SQL tutorial go to: https://www.1keydata.com/sql/sql.html
