Vulcan Block Model to Voxel(s)
Use the Voxel > Conversions > Vulcan Block Model to Voxel(s) menu option (geogxnet.dll(Geosoft.GX.ImportVulcanBlockModel;Run)*), to import a Vulcan Block Model file to Geosoft Voxels.
Import Vulcan Block Model to Voxel(s) dialog options
Vulcan block model file |
Browse to select the Vulcan Block Model file to be imported. Script Parameter: IMPORTVULCANBMF.INPUT_BMF |
Output voxel file prefix |
Specify the name of the Geosoft Voxel file to generate (.geosoft_voxel). If more than one field is selected for import, this name is used as a prefix, along with the selected field name(s) to create the actual output file name. For instance, if the output voxel file prefix is "Test.geosoft_voxel", and the two fields "Ag" and "Au" were selected for conversion to Geosoft voxel files, then the actual output file names would be "Test_Ag.geosoft_voxel" and "Test_Au.geosoft_voxel." Script Parameter: IMPORTVULCANBMF.OUTPUT_VOXEL |
Set Vulcan default value blocks to dummy |
Vulcan block models can contain numerous cells which have a 'default value'. This value is sometimes -99 and is meant to represent null or empty cells, in which case the user might want to exclude these values from the import. In other cases, this default value might be used as a background, or common value, in which case the user might want to retain these values in the import. Script Parameter: IMPORTVULCANBMF.REMOVEDEFAULTVALUES |
Numeric Variables
Variables to import |
Select the numeric fields that you wish to import. Vulcan block models can contain numerous variables, while Geosoft voxels only store a single variable per voxel. If you choose to import more than one variable from the Vulcan block model, then the same number of Geosoft voxels will be created, using the name convention described above in Output voxel file prefix. Script Parameter: IMPORTVULCANBMF.VARIABLES_TO_IMPORT |
String Variables
Variable to import |
Select the string field that you wish to import. Vulcan block models can contain numerous variables, both numeric and text; if you choose to import a string variable, then a Geosoft voxel that can store string values will be created. Geosoft voxels which store string values are called "Lithology" or "Thematic" voxels. Script Parameter: IMPORTVULCANBMF.VARIABLES_TO_IMPORT |
Rock code file |
Select an existing rock code file that contains codes which match the values in the input variable; the assigned colours in the rock code file will be used to display the output voxel. If you do not have a rock code file that corresponds to the string values in the selected variable, leave this option blank and a series of random colours will be assigned to the incoming string values. In this case, a default rock code file will be created and saved in the same folder as the output voxel file. Script Parameter: IMPORTVULCANBMF.ROCK_CODE_FILE |
Coordinate System
If a 3D Viewer is open when running the import, then all output voxels will be displayed in the 3D Viewer window. Otherwise, the output voxels will be each displayed into a new Voxel Viewer window. If the output voxel does not display, open the Advanced Settings dialog (Project > Settings > Advanced) and under the Voxel Settings section, check if the Display Created Voxels option is set to "True".
If the Rock code file option is left blank on import of String variables, then a default rock code file is created and saved during import. A unique file name is assigned based on the output voxel file name (e.g. if the output file name is ‘output_variablename.geosoft_voxel’, then the default rock code file will be called 'output_variablename_rockcode.csv’). You can then modify this rock code file using the DH-Data > Edit Rock Codes menu item.
If you do edit the default file, be sure to save it with a new name, as the default file will be overwritten by subsequent imports.
The output voxel cell size is chosen as the highest resolution cell size among the schemas found in the block model.
