Import Surpac STR or DTM File(s)
Use the Map > Import > Surpac STR or DTM File(s) menu option (IMPSURPAC GX) to import a Surpac STR or DTM file into an Oasis montaj map.
Use the Add to 3D > Imports > Surpac STR or DTM File(s) menu option (IMPSURPAC GX) to add a Surpac STR or DTM file to a 3D View.
Surpac STR and DTM File Import dialog options (3D View)
Surpac STR or DTM file(s) |
Select one or more Surpac STR or DTM files to import. Script Parameter: IMPSURPAC.FILES (Separate files with the "|" character. |
Surpac STR and DTM File Import dialog options (Map)
Current Map |
Click this button to import the file(s) to the current map. Script Parameter: IMPSURPAC.MAPOUT (Option: 0: Current Map) |
New Map |
Click this button to import the file(s) on a new map. Script Parameter: IMPSURPAC.MAPOUT (Option: 1 : New Map) |
Import to a New Map dialog options
Create a New Map dialog options
Map name |
Specify the name of the new map. Automatically pre-populated with the same name as the input Surpac STR or DTM file name. Script Parameter: IMPSURPAC.MAP |
If the Surpac STR or DTM file(s) are imported to a current map, the imported data will be projected onto the plane of the current data view. If the view is a normal "plan" view, then the Z-dimension information will be lost. If the view is a "section" view (such as those created for drillhole sections in Target), the data is projected horizontally onto that plane. If imported to a 3D View, the objects are plotted as in the original files.
