Import UBC Mag3D Model(s)
Use the Database > Import > UBC Mag3D Model(s) menu option (IMPUBCMODMSH GX) to import UBC 3D Model & MSH files to a Geosoft Database.
Import UBC Mag3D Model(s) dialog options
MSH Header File Format
This file contains the 3D mesh which defines the model region. The mesh has the following structure:
E0 N0 V0
?E1 ? E2 ... ? ENE
? N1 ? N2 ... ? NNN
?V1 ? V2 ... ? VNV
NE Number of cells in the East direction.
NN Number of cells in the North direction.
NV Number of cells in the vertical direction.
E0, N0, V0 Coordinates, in meters, of the southwest top corner, specified in (Easting, Northing, Elevation).
Model File Format
Model files consist of a total of NE*NN*NV values, one per line, as in the following example:
-9.0000000e+000
1.0607292e+001
1.0642567e+001
1.0762947e+001
1.0782325e+001
1.0803412e+001
1.0837755e+001
etc...
The following is the file structure of model.sus:
sus1,1,1
sus1,1,2
sus1,1,NV
sus1,2,1
susi,j,k
susNN,NE,NV
susi,j,k susceptibility at location [i j k].
[i j k]=[1 1 1] is defined as the cell at the top-south-west corner of total number of lines in this file should equal NN NE NV, where NN is the in the North direction, NE is the number of cells in the East direction, and NV cells in the vertical direction. The lines must be ordered so that k changes the 1 to NV), followed by j (from 1 to NE), then followed by i (from 1 to NN).
The dummy value is -9.0, and is automatically converted to a Geosoft dummy on import.
The above descriptions are derived from the following document:
MAG3D
A Program Library for Forward Modelling and
Inversion of Magnetic Data over 3D Structures
VERSION 3.0
Developed under the consortium research project
JOINT/COOPERATIVE INVERSION OF
GEOPHYSICAL AND GEOLOGICAL DATA
UBC–Geophysical Inversion Facility
Department of Geophysics and Astronomy
University of British Columbia
Vancouver, British Columbia
