Import Gemcom File
Use the Map > Import > Gemcom BT2 File menu option, (geogxnet.dll(Geosoft.GX.Map.Gemcom;Run2D)*), to import a Gemcom BT2 file into an Oasis montaj map.
Use the Add to 3D > Imports > Gemcom File menu option, (geogxnet.dll(Geosoft.GX.Map.Gemcom;Run)*), to add a Gemcom file (BT2, BPR, or BPR2) to a 3D View.
Gemcom Import dialog options (3D View)
File to import |
Select the Gemcom file to import to the current 3D view. Script Parameter: GEMCOM.INPUTFILE |
Import Gemcom BT2 File dialog options (Map)
Gemcom File Types
The Gemcom files that can be imported into an Oasis montaj map are of the type BT2 (binary triangulation files).
The Gemcom file formats that can be imported into a 3D View are BT2 and the block model types: BPR and BPR2.
The import of block model types (.BPR , .BPR2), requires additional files:
- A .CAT file that points to a folder containing the .BLK, .BLK2 files
- A .BLF2 file with the same name as the folder containing the .BLK and .BLK2 files
