Make Fid Channel
Use the Database Tools > Channel Tools > Make Fid Channel menu option (MAKEFID GX) to create a fiducial channel based on a specified reference channel. The reference channel is used to determine a start fiducial, fiducial increment, and number of elements to create.
Make Fid Channel dialog options
Base fiducial on channel |
Channel from which to derive the fiducial start, increment and number of elements. Script Parameter: MAKEFID.IN |
Fiducial channel name |
Name of the created fiducial channel. Script Parameter: MAKEFID.OUT |
Fiducial type |
Fiducial data type, one of BYTE, SHORT, LONG, FLOAT, or DOUBLE. Default is "FLOAT". Script Parameter: MAKEFID.TYPE |
If a fiducial channel may be required for math calculations or for exporting to an XYZ file, his GX enables you to create a fiducial channel for such purposes.
