Print Multiple Maps (Batch Printing)
For high efficiency automated printing and plotting, Oasis montaj provides a batch printing capability. This capability enables you to specify a number of plots and print them sequentially without any hands-on intervention. The batch printing option is only available in the licensed version of Oasis montaj.
Use the Batch Printing option (MAPPRINT GX) to print one or more maps to the default printer:
On the Project menu, select Print > Batch Printing. The Batch Printing dialog is displayed.
Using Browse button, select one or more maps.
Using the drop-down lists and text boxes, specify the scale, page layout, offsets, overlap, destination, output file name and number of copies.
Click the OK button. The specified maps are sent to your installed printer or plotter.
Note that the current printer settings are used.
Batch Printing dialog options
Maps to print |
A list of one or more map file names. If there is more than one map file specified, map names should be separated by a " | " (vertical bar) character. Multiple files may also be selected from the browse tool. Script Parameter: MAPPRINT.MAPS |
Scale option |
Map scaling options:
Script Parameter: MAPPRINT.SCALETOFIT |
Scale Factor |
Scale multiplier, default is 1.0 unless "Fit to page" Script Parameter: MAPPRINT.SCALFACTOR |
Pages |
Specify "All pages" to print all pages of a multi-panel map, or "Range of pages" to select a subset of pages tp plot. Script Parameter: MAPPRINT.ALLPAGES |
Start page |
Specify the first page to print if "Range of pages" is selected. Script Parameter: MAPPRINT.FIRSTPAGE |
End page |
Specify the last page to print if "Range of pages" is selected. Script Parameter: MAPPRINT.LASTPAGE |
Location on page |
The plots may be "Centered" on the page or "Offset" from the bottom left by the distance specified next. Script Parameter: MAPPRINT.CENTRE |
X offset (mm) |
The offset from the bottom left for "Offset" location. Script Parameter: MAPPRINT.OFFSETX |
Y offset (mm) |
The offset from the bottom left for "Offset" location. Script Parameter: MAPPRINT.OFFSETY |
Overlap size (mm) |
The overlap between panels for multi-panel plots. Script Parameter: MAPPRINT.OVERLAPSIZE |
Destination |
The plot may be sent to the current default printer or sent to a file. Multi-panel plots sent to a file will produce a set of files with extensions .0, .1, .2, etc. Script Parameter: MAPPRINT.PRINTTOFILE |
Output file |
If sending plot to a file, this is the name of the file. The FILEPRNT GX can be used to print the saved print files. Script Parameter: MAPPRINT.FILENAME |
Copies |
The number of copies desired. Script Parameter: MAPPRINT.COPIES |
