Snap Grid Resolution
Use the Map > Settings > Snap Grid Resolution menu option (MAPSNAP GX) to set the resolution for the SNAP function in millimeters for the current map.
Snap Grid Resolution dialog options
Resolution in mm |
Specify the resolution of the snap feature in millimeters (default = 1). Script Parameter: MAPSNAP.RES |
The SNAP feature is used in Oasis montaj ™ from the Map menu.
