Build Solution Channel
Use the Copy a Channel against Mask Channel dialog option (MASKCPCH GX) to copy one channel to another against a mask channel.
Copy a Channel against Mask Channel dialog options
Copy From |
Original channel. Script Parameter: MASKCPCH.from |
Copy To |
Destination channel. Script Parameter: MASKCPCH.to |
Mask Chan |
Mask channel. Script Parameter: MASKCPCH.mask |
If a new channel does not exist, it will be created with the same definition as the original channel. Where the mask channel value is a dummy "*", the copied value will be set to a dummy; otherwise the data is copied as is, subject to the usual rule on data conversion if the original and destination channels are different types.
